NA6 seat belt warning light on dash staying on when seatbelt plugged in
twr7cx
Postby twr7cx » Mon Mar 23, 2020 2:05 pm
Recently the red warning light on the dash of my NA6 is not going out when I plug in the seatbelt. It goes out briefly when the seatbelt buck is initially pushed in but once it's pushed all the way down and latches it comes back on. I realise that this must be integrated as part of the drivers side seatbelt receiver. Is there an easy fix (e.g. open up and clean out, rebend a sensor tab that's lost it's spring etc) or is a replacement receiver required?
Re: NA6 seat belt warning light on dash staying on when seatbelt plugged in
Postby bruce » Mon Mar 23, 2020 6:56 pm
Firstly, ADM NA6s don't have a seatbelt light (I think). Thus yours must be JDM, as supported by the 180km/h speedo.
But why are you doing 120km/h and then taking a photo!
twr7cx
Postby twr7cx » Tue Mar 24, 2020 9:50 am
bruce wrote:Firstly, ADM NA6s don't have a seatbelt light (I think). Thus yours must be JDM, as supported by the 180km/h speedo
Yes, it is a JDM import. 89 NA6C.
bruce wrote:But why are you doing 120km/h and then taking a photo!
I’m not. It’s not my photo, it’s just one I found to use to show the seatbelt light that I am referring to. Does it matter though in relation to the actual question asked as I haven’t found any evidence that the vehicles speed has a correlation to the issue.
ralt
Postby ralt » Tue Mar 24, 2020 4:00 pm
Hi
It is obviously a real problem as the americans could not solve the problem for you. Perhaps the easiest way would be to snip the wire behind the instrument binnacle which would solve something which was not really important. Some things are not worth worrying about.
SuperMazdaKart
Postby SuperMazdaKart » Tue Mar 24, 2020 6:57 pm
Maybe a good dose of electrical contact cleaner or isopryl propanol into the buckle might help
twr7cx
Postby twr7cx » Wed Mar 25, 2020 9:26 am
ralt wrote:It is obviously a real problem as the americans could not solve the problem for you. Perhaps the easiest way would be to snip the wire behind the instrument binnacle which would solve something which was not really important. Some things are not worth worrying about.
Not exactly how I would categorise it but anyway. Yes, I learnt from them that it seems to be a JDM feature, since with the LHD and RHD thing there’s not many JDM vehicles over there compared to here I brought the question over here. While I could modify the wiring to remove the feature it’s not my preferred course of action as I’d rather rectify the actual fault and keep the car a bit more complete/original. It’s not a major concern of mine by any measure but rather something that I thought someone on here may have previous experience/knowledge on to share.
SuperMazdaKart wrote:Maybe a good dose of electrical contact cleaner or isopryl propanol into the buckle might help
Probably can’t hurt to try.
SuperMazdaKart
Postby SuperMazdaKart » Wed Mar 25, 2020 11:32 am
Might be worth contacting some JDM import autowreckers if you end up wanting to replace. There's a NA6 Eunos Roadster being parted that's on eBay at the moment at Southside JDM Imports in NSW. https://www.ebay.com.au/itm/Mazda-MX5-eunos-roadster-miata-na-89-97-guard-indicator-wrecking-car-complete/223512755181?hash=item340a65fbed%3Ag%3AOxUAAOSw8S5c15qw&LH_ItemCondition=4
Might even be possible to swap the passenger one to the driver side temporarily.
Postby bruce » Wed Mar 25, 2020 12:24 pm
I would just cut the wire and twist them together.
twr7cx
Postby twr7cx » Thu Mar 26, 2020 11:01 am
Cheers SuperMazdaKart.
