Passenger side rear tow hook for NA?
twr7cx
Postby twr7cx » Wed Oct 31, 2018 9:32 pm
Anyone able to advise where I can acquire a rear tow hook that will fit on the passenger side (opposite to the exhaust tip outlet) on an NA? The MX5Mania ones < https://www.mx5mania.com.au/epages/mx5m ... hooks-0001 > only fit the drivers side next to the exhaust outlet.
apsilon
Re: Passenger side rear tow hook for NA?
Postby apsilon » Thu Nov 01, 2018 6:20 am
I recently fitted one from Jass Performance, the Dural powder coated version IIRC. Never used it so can't comment further really.
'97 Neo Green limited edition
twr7cx
Postby twr7cx » Sun Nov 11, 2018 6:16 am
apsilon wrote:I recently fitted one from Jass Performance, the Dural powder coated version IIRC. Never used it so can't comment further really.
Fitted to the passenger side?
This one < https://www.mx5mania.com.au/epages/mx5m ... ID=5779379 > I assume?
apsilon
Postby apsilon » Sun Nov 11, 2018 7:15 am
Yes, passenger side. I think that's the one though I bought the black powdercoat version so it doesn't stand out.
twr7cx
Postby twr7cx » Thu Dec 06, 2018 9:34 am
Cheers. I've bought one and installed it but am planning to change the setup as I noticed that the bolt holes in the two hook are larger diameter than the OEM bolts (which are either M6 or M8 size I think) - I was wondering either making spacers up or drilling it out and fitting bolts of a more substantial size through there.
RS2000
Postby RS2000 » Thu Dec 06, 2018 5:28 pm
Believe it or not, but the minimum breaking load in single shear of a 6mm high tensile bolt shank is about 1400 kg. One would lift your car of the ground. Two will be more than fine for towing.
Postby bruce » Thu Dec 06, 2018 7:39 pm
As if it's going to be used for towing.
twr7cx
Postby twr7cx » Tue Dec 11, 2018 3:51 pm
bruce wrote:As if it's going to be used for towing.
While hopefully it won't need to be used, I think it's dangerous to leave something like that fitted if it's not secured properly incase it's used by someone - if they let go they can do some serious damage!
Postby NitroDann » Wed Dec 12, 2018 8:19 am
They are M8 and if you went and purchased 2x 10.9 High tensile bolts for a dollar each you would have a towhook capacity of just under 7 tonnes.
Dont overthink it.
apsilon
Postby apsilon » Wed Dec 12, 2018 9:15 am
FWIW, mine came with (or did I order them separately?) 10.9 fasteners.
