Which Seat, NC, Track only
Posted: Fri Aug 03, 2018 3:59 pm
by MrTurkey
Hi Guys,
What seat should I look at for my NC track only build?
I am 180cm and 100kg (i know, heavy)
My location makes it difficult to get to go try some out. I would try to before putting down the $$$ though.
I am going to get a full cage built at some stage. What direction should I go that won't cost the earth?
Thanks,
Chris
Re: Which Seat, NC, Track only
Posted: Sun Aug 05, 2018 9:29 pm
by david_syd_au
I have Sparco Pro2000 seats in my NC race car. The driver's seat is on a Sparco race slider with custom mounts, while the passenger seat is on the std mount points with no slider.
FWIW, i am 186cm and a bit over 100kg.
The Pro2000 seats are slightly narrower than the Sprint V's in my wife's NB race car, but I fit ok.
The NC had a cage when I bought it, but for the NB we had a cage built by Phil from Street Neat Welding near Gosford. It was the 26th MX-5 cage he had done and cost around 1800 back in 2013.
Posted: Fri Aug 17, 2018 9:41 pm
by Custardtart
I’ve been looking at the Sparco Grid2
Posted: Tue Aug 21, 2018 5:21 pm
by MrTurkey
Thanks guys, just saw your replies now.
Unrelated, do you run without the rear bar or run a cut rear bar?
Posted: Thu Aug 23, 2018 2:29 pm
by Custardtart
MrTurkey wrote:Thanks guys, just saw your replies now.
Not sure what you mean? I run a brown davis bar that has removable rear stays so the soft top reclines. It’s CAMS approved but a hard top doesn’t fit over it.
The harness attaches to a cross member behind the seats.
I had SAAS seats but they were too big. I had them mounted to a custom frame which attached to the existing seat bolting points.
Posted: Mon Oct 29, 2018 9:07 pm
by MrTurkey
What do you think of the Sparco Ergo II? These guys think it might be a fit for me...
http://www.racerindustries.com.au/afawc ... -2018.html
