Hi Guys,
What seat should I look at for my NC track only build?
I am 180cm and 100kg (i know, heavy)
My location makes it difficult to get to go try some out. I would try to before putting down the $$$ though.
I am going to get a full cage built at some stage. What direction should I go that won't cost the earth?
Thanks,
Chris
Which Seat, NC, Track only
- david_syd_au
Re: Which Seat, NC, Track only
I have Sparco Pro2000 seats in my NC race car. The driver's seat is on a Sparco race slider with custom mounts, while the passenger seat is on the std mount points with no slider.
FWIW, i am 186cm and a bit over 100kg.
The Pro2000 seats are slightly narrower than the Sprint V's in my wife's NB race car, but I fit ok.
The NC had a cage when I bought it, but for the NB we had a cage built by Phil from Street Neat Welding near Gosford. It was the 26th MX-5 cage he had done and cost around 1800 back in 2013.
- Custardtart
I’ve been looking at the Sparco Grid2
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
Thanks guys, just saw your replies now.
Unrelated, do you run without the rear bar or run a cut rear bar?
- Custardtart
MrTurkey wrote:Thanks guys, just saw your replies now.
Not sure what you mean? I run a brown davis bar that has removable rear stays so the soft top reclines. It’s CAMS approved but a hard top doesn’t fit over it.
The harness attaches to a cross member behind the seats.
I had SAAS seats but they were too big. I had them mounted to a custom frame which attached to the existing seat bolting points.
Lakeside 62.3
Lakeside 62.3
What do you think of the Sparco Ergo II? These guys think it might be a fit for me...
http://www.racerindustries.com.au/afawc ... -2018.html
Users browsing this forum: No registered users and 56 guests
