Bumper repairs
RobJ
Bumper repairs
Postby RobJ » Sat May 12, 2018 10:44 pm
Hi all,
I have a cracked front bumper and am sick of its ugliness, so looking to repair it (must likely myself, the car is a diy project).
I'm thinking plastic weld into the crack, let it harden then reinforce the inside with fibreglass. However, I'm not sure how to get it all nice and smooth for painting?
Anyone out there got experience with bumper repairs?
RobJ
Re: Bumper repairs
Postby RobJ » Sat May 12, 2018 11:01 pm
Pic of the crack looking unhappy
RobJ
Re: Bumper repairs
Postby RobJ » Sat May 12, 2018 11:03 pm
Pic of the crack straightened up
RobJ
Re: Bumper repairs
Postby RobJ » Sat May 12, 2018 11:04 pm
(pics will rotate to proper orientation if you click them)
bonester
Re: Bumper repairs
Postby bonester » Sun May 13, 2018 11:17 pm
If it is an NA the front bar is polyurethane and the rear something else which escapes me. Urethane cannot be plastic welded but can be repaired. I used this stuff to fill holes in mine:
http://www.supercheapauto.com.au/Produc ... Kit/545159
I used the smaller kit which is cheaper but you might need the bigger one.
Re: Bumper repairs
Postby 93_Clubman » Sun May 13, 2018 11:26 pm
Yeah, to fill holes, like when debadging, an ISO Plastic Parts Filler can be used.
Re: Bumper repairs
Postby hks_kansei » Mon May 14, 2018 1:24 pm
Regarding how to smooth the plastic for paint after repairs are done.
This is as simple as lightly sanding it.
use a decent quality sandpaper, preferably a wet/dry type.
depending on how rough the plastic is, maybe start at 400 grit and move down step by step to about 1200, or maybe even smoother.
If a panel shop will be painting it, leave the sanding to them, as they'll do it to whatever grit/method works best for their technique and paints.
