Slow power window - Honda Shin-Etsu grease
Posted: Mon Apr 09, 2018 3:19 pm
by twr7cx
So the Miata guys seems to froth on using Honda Shin-Etsu grease to lubricate their windows (e.g.
http://wiki.miata.net/tiki-index.php?pa ... Window+Fix ).
My passenger side power window has significantly slowed down now. Seems that the Honda Shin-Etsu grease is not so easily sourced locally. Any recommended suppliers or alternative products? Is it just a silicone based grease?
Re: Slow power window - Honda Shin-Etsu grease
Posted: Mon Apr 09, 2018 3:36 pm
by hks_kansei
Should be able to use any rubber safe grease.
White lithium grease is one of the more common ones if i recall.
Posted: Mon Apr 09, 2018 4:21 pm
by ManiacLachy
I bought it on eBay. You only need a little so it's not a great value proposition. White lithium would do the trick just as well, like hks said.
The important thing I found was to remove the glass and probably the runner from the door and thoroughly remove any old clumps of grease. Use a cotton bud to get into the channels. And remove and clean, or replace the bushing on the glass.
It seems like a lot of work, but the changes are drastic.
Posted: Fri Apr 13, 2018 11:12 pm
by siege
I guess this is the route I'll have to go when I can bring myself to take the doors apart again and face getting more tar on my clothes and hair.
I tried the quick and easy fix with WD40 silicon specialist spray. nup that fix didn't last long.
Posted: Sun Apr 15, 2018 9:58 am
by 3gress
Rolley posted a great DIY on replacing the window guide bushes that describes disassembly and cleaning procedure.
He was selling replacement guide bushes a while back, maybe worth contacting him to see if he has a spare set available.
http://mx5cartalk.com/forum/viewtopic.php?f=76&t=72566
Posted: Mon Apr 16, 2018 7:19 am
by wasp47
Hi
I have a set of DELRIN bushes for sale in you are interested. New Still sealed in packet.
Pm if interested.
Steven
