NA6 - did they have factory fitted front grill?
Posted: Wed Mar 28, 2018 12:29 pm
by twr7cx
Should my 89 JDM NA6 have a factory fitted front grill in the air dam of the front bar? If not, where/how are the aftermarket ones that I see available for sale mounted?
Re: NA6 - did they have factory fitted front grill?
Posted: Wed Mar 28, 2018 2:12 pm
by NitroDann
Nope. Rivets and bolts and the like.
Posted: Wed Mar 28, 2018 2:19 pm
by hks_kansei
As above, no factory grille, just an open hole and the radiator behind it.
Most of the aftermarket ones just mount with a couple of screws and small brackets.
Personally I think the grilles look rubbish, but different strokes etc.
Posted: Thu Mar 29, 2018 3:04 pm
by GCMX5
I made my own which fits with rubber friction.
Does not look obvious in its location. Keeps stones and bugs from damaging or blocking any of the coolers.
Posted: Wed May 23, 2018 11:02 am
by shirtz
GCMX5 wrote:I made my own which fits with rubber friction.
and significantly reduces airflow..
Posted: Wed May 23, 2018 11:19 am
by hks_kansei
I wouldnt say significantly, depending on the mesh type.
Most stuff will still flow fine, unless it's that godawful drilled steel that was all the rage in the 90s.
Posted: Wed May 23, 2018 8:04 pm
by GCMX5
