Paint code Silver
- Vehicle: NA8 - Supercharged
Paint code Silver
I just picked up a hardtop, it's silver with demisted rear window. Original colour. Seller reckons it was from an NA. what was paint code for silver NA. I need to get some touch up paint.
Re: Paint code Silver
> can anyone chime in with when heated rear window's were introduced? was that part way through NA?
Does the hardtop match the car colour? If it does, then there will be a paint code on the manufacture plate on the firewall. Probably "3L".
Otherwise, some links that might help;
post from 93_clubman with codes http://mx5cartalk.com/forum/viewtopic.php?f=76&p=920641#p920508
site with photo's of the colours (note - USA site so not sure if they all apply here) https://www.miata.net/gallery/na.html
NA6 '89 red, NB8B '01 silver
3L on mine.
ianoz wrote:can anyone chime in with when heated rear window's were introduced? was that part way through NA?
Following Hardtop FAQ should contain the info you're after: https://www.miata.net/garage/hardtop/
Thanks folks! No it doesn't match the car colour, car is red with silver wheels, sometimes black wheels, anyway I can live with a silver top on a red car, it kinda grows on you.
