Fix for main cause of water leaking onto NB ECUs
davekmoore
Postby davekmoore » Sat Apr 22, 2017 3:44 pm
Sit in passenger seat. Gently move right foot up (or feel around above where your right foot would be) until you feel a rubber hose. Remove hose from black air con box. Fit clamp onto hose. Replace hose. tighten clamp. It is now very unlikely that the hose can fall off or be kicked off.
