How to remove clubman boot sticker
chefie
Postby chefie » Mon Feb 20, 2017 9:04 pm
Hi all
I need to repsary the Boot lid and need advice
Do the clubman stickers come off easy and without damage or do i just tape around it and clean up after, its only a acrylic respray on the boot
thanks
98 NB8A Grace Green
LS 66.17,QR Club 69.27, QRSpr 63.58 SOLD
01 NB8B Grace Green
LS 64.66,QRNat 1.31.94,QR Club 65.17 QRSpr 62.36
93 NA8 Clubman
lucmor444
Re: How to remove clubman boot sticker
Postby lucmor444 » Mon Feb 20, 2017 9:37 pm
Most car badges are affixed by double sided tape. To remove you heat them up carefully with a heat gun/hairdryer. That will soften the tape and adhesive and you should be able to carefully remove the badge - if necessary use some dental floss to run behind the badge and the body work to 'cut' through any stubborn parts of the adhesive/tape parts. Just get some 3M double adhesive tape to stick the badge back on,
Postby Mr Morlock » Tue Feb 21, 2017 9:02 am
lucmoor is right when it comes to a proper badge i.e. a plastic moulded badge e.g. like the thousands of Ford badges which were fixed with d/s tape. The Clubman version I think is just a sticker so it has adhesive on the back like a service label or old reg sticker. It would be easier just to mask it over.
Postby 93_Clubman » Tue Feb 21, 2017 12:05 pm
Clubman boot lid sticker has an adhesive backing, but it's also not a simply manufactured sticker, although it can look that way after years of exposure on the boot lid. Try a hairdryer or masking as per above.
chefie
Postby chefie » Wed Feb 22, 2017 8:55 pm
Mr Mortlock and 93 clubman are correct it is a sticker with raised surface and i dont think it will come off without damage after the sun damage the boot has
I think i will try the kids school book contact and a razor blade then try a spray, it an acrylic paint so ill redo if dodgy
Thanks 93 clubman for the guidance on a new sticker
98 NB8A Grace Green
01 NB8B Grace Green
93 NA8 Clubman
billybunter
Postby billybunter » Thu Feb 23, 2017 11:42 am
I would try soaking it several times in goo remover and over a few hours see if it will penetrate to the back of the sticker. all you really need is a bit of a lift in one corner then get a grip :lol - and use a hairdryer on low heat and peel it back - it's gone :wink:
Postby hks_kansei » Thu Feb 23, 2017 12:42 pm
Billys idea would work, but since the clubman sticker is a resin rubbery domed thing from memory, you could discolour, or fog the resin.
I'd take some detailed photos of the sticker and just look on the web for a company that can make a replacement.
Postby 93_Clubman » Thu Feb 23, 2017 1:25 pm
Yeah, the domed part is a lens over the whole sticker, which eventually deteriorates completely leaving just the adhesive backed flat Clubman sticker. A remake by the original sticker manufacturer & supporting businesses was facilitated by Mazda Australia & myself some years ago, so a supply is available.
billybunter
Postby billybunter » Thu Feb 23, 2017 3:15 pm
or you could just paint straight over it and add the text :lol: :roll: shortly I will have to do something similar to a motorbike tool box. it will be interesting what happens my way :lol:
billybunter
Postby billybunter » Thu Feb 23, 2017 3:21 pm
forgot to add.....if you ever want to remove the adhesive residue from stickers attacked to the car I tried several. I found goo remover was by far the best of the lot and did the job extremely well.
some of the so called greens or friendly to the environment types were totally useless and would end up residing in the bottle till eternity :lol:
chefie
Postby chefie » Sat Feb 25, 2017 6:16 pm
Thanks billy
I can go at the existing sticker with a chisel, hair dryer gunk, goo and all the best stuff because I thought a new Clubman 1993 sticker would be impossible to track down.
Gotta love a forum and the MX5 passion . I so happy i could :D
98 NB8A Grace Green
01 NB8B Grace Green
93 NA8 Clubman
Users browsing this forum: No registered users and 49 guests
