Handbrake button remains down
Postby bruce » Wed Dec 14, 2016 3:02 pm
Howdy,
I have an intermittent problem. The button on the handbrake remains depressed, thus locking the handbrake.
I've removed the plastic cover and can release the button by prodding the 'teeth' (tech term). It appears either the teeth lock together, or there's something wrong with the rod attached to the button.
I've lubed the teeth mechanism with no result. Any advice?
Ta
Bruce
Rolley
Re: Handbrake button remains down
Postby Rolley » Wed Dec 14, 2016 4:09 pm
Was there any adhesive/glue/gum holding the plastic handle on?
I have come across Lasers/323's (basically the same part) where that adhesive had melted and wicked up into the gap left where the folded metal edges meet inside the handle under the handbrake leaver.
The adhesive gums up the button from freely sliding in the leaver. A dunk in some acetone, a bit of jiggling and a spray of dry PTFE lube got them working again.
Postby bruce » Wed Dec 14, 2016 5:34 pm
The button moves freely. Maybe some gunk inside the handle?
Tigger
Postby Tigger » Thu Dec 15, 2016 1:10 pm
Its modified itself to drift easier.
Postby bruce » Thu Dec 15, 2016 2:26 pm
But it doesn't release!
Obviously something is worn, but I can't figure out what (and how to replace)?
Tigger
Postby Tigger » Mon Dec 19, 2016 8:49 am
Iirc, its just a sheet Metal part made to be cylindrical.
A. Are you able to remove the handle?
If yes, remove it, and see if there is anything obstructing the button.
B. Does the button pull out if you pull on it? Or, if you stick something to it and pull?.
If yes, then it sounds like the spring inside is gone.
I BELIEVE the button is threaded in, so wrap something like a strip of leather around it and twist gently to remove it. I say gently because it's plastic.
This is just conjecture, but may help lead to the solution.
Postby bruce » Mon Dec 19, 2016 11:26 am
The button unscrews.
It's not the button which is faulty, it's either the rodded mechanism, or the gears at the base (I reckon theyre worn).
smy0003
Postby smy0003 » Mon Dec 19, 2016 11:29 am
I've got a spare mechansism if you want Bruce?
Sent from my LG-H815
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Postby bruce » Mon Dec 19, 2016 11:36 am
Thanks. I'll message you a bit later to discuss.
Postby bruce » Thu Dec 22, 2016 11:59 am
Thanks to smy for supplying a new handbrake.
