How to recover NA door cards
Posted: Fri Nov 18, 2016 10:17 am
Hello! I decided I'd do a write up on my tan conversion, first up, doors!
So after pulling your doors off, you should have a panel like this,
You'll have to seperate the top from the bottom.
To seperate the panels begin removing the screws from the backside of the door where the top meets the bottom.
Then you'll have to remove the staples that hold the leather from the top piece to the bottom piece, pictured below
Once you have done this, you can seperate the two pieces.
