NA8squeak from front of engine on starting
Posted: Wed Jun 29, 2016 2:57 pm
by lonesailor
My NA8 gets a squeak ,sounding like a dry bush or seal ,when starting from cold . It only lasts 5-10 seconds and appears to come from either the water pump ,PS pump ,ac clutch or alternator. I don't particularly want to go on a drawn out fishing expedition to find it. Has anyone had a similar problem who could point me in the right direction. I've tiied a little CRC without much success,and don't think it's a belt slipping.
Re: NA8squeak from front of engine on starting
Posted: Wed Jun 29, 2016 3:57 pm
by smy0003
Tighten your accessory belts.
Posted: Thu Jun 30, 2016 11:16 am
by lonesailor
Have done that,I think it may have sorted it.They seem to need a bit more tension than I thought.
Posted: Thu Jun 30, 2016 11:38 am
by sjmarcy
A worn damper / crank pulley can do that too. The rubber ring between the pulley and hub sections can go bad. Often but not always you can see some wobble at idle.
