NA8squeak from front of engine on starting
My NA8 gets a squeak ,sounding like a dry bush or seal ,when starting from cold . It only lasts 5-10 seconds and appears to come from either the water pump ,PS pump ,ac clutch or alternator. I don't particularly want to go on a drawn out fishing expedition to find it. Has anyone had a similar problem who could point me in the right direction. I've tiied a little CRC without much success,and don't think it's a belt slipping.
- smy0003
Re: NA8squeak from front of engine on starting
Tighten your accessory belts.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Have done that,I think it may have sorted it.They seem to need a bit more tension than I thought.
A worn damper / crank pulley can do that too. The rubber ring between the pulley and hub sections can go bad. Often but not always you can see some wobble at idle.
