Page 1 of 2
RHD Phone mount
Posted: Thu Jun 09, 2016 12:16 am
by guss_bruss
I've been looking for a way to mount an iPhone in the cabin but I can't really seem to find anything on the market which currently fits my needs, I was wondering has anyone found a phone mount which is strong enough for track days and spirited driving as well as being out of immediate line of sight (not mounted to windows or windscreen)?
So far i'm pretty set on something like this
http://www.mossmiata.com/Shop/ViewProducts.aspx?PlateIndexID=80390&SortOrder=1 but I don't think they were ever made for a RHD configuration, has anybody had any luck finding anything similar that's not the Brodit mounts?
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 8:44 am
by smy0003
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 8:46 am
by pie5
These are a little expensive but work well.
I have used them in a variety of different cars.
http://www.holdmyphone.com.au/mounts/car/mazda/mx5.html
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 9:50 am
by RileyR
I bought one of these, used the dash mount and placed it next to the cluster. I superglued all the bits that can move and swivel so it stays put. Havent tested on track yet but has handled some spirited driving.
http://m.ebay.com.au/itm/231180960747?_mwBanner=1Sent from my SM-G900I using Tapatalk
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 11:34 am
by guss_bruss
Have you used this in an NB mx5? I'm just worried with such a big phone such as the iPhone 6 plus it would sit too close to the gearknob, A/C controls and stereo. i'm also worried it wouldn't allow for landscape use of the device for the same reasons, does anyone have any experience with these mounts?
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 11:36 am
by guss_bruss
Also I should have mentioned with the other two links mounts, i'm looking to keep it off the top of the dash as much as possible to avoid it taking up space, that Zoom one looks good but it would probably restrict view out the windscreen.
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 1:18 pm
by smy0003
Stick it to the quarter side window glass
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 6:16 pm
by hks_kansei
Buy a generic phone holder, then buy some aluminium L section (or flat section)
Bolt the alu to something in the cabin (console side bolt likely easiest, under the rectangle cover) and then bolt/glue the phone cradle to the other end of the alu.
Should be rock solid, and you can pick how high/where it's mounted.
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 10:23 pm
by bear2230
I have one of these and an I-Phone 6 and they are very good.
http://www.proclipusa.com/dashboard-mou ... torright=1
and this holder
http://www.proclipusa.com/phone-holders ... -case.cmsv
Richard.
Re: RHD Phone mount
Posted: Thu Jun 09, 2016 10:49 pm
by bigdog
I use a Ram X mount with a ball plate screwed to the side of the console below the dash on the passenger side. There was an old phone mount screwed on there when I bought the car, so holes were already there. It's the best phone mount I've ever had, and fits any phone. You can buy model specific mounts if you prefer.
http://www.hurtlegear.com.au/ram-hol-un ... th-1-ball/
Re: RHD Phone mount
Posted: Thu Jun 16, 2016 11:15 pm
by guss_bruss
The links you gave me don't work but is that the mount which sits on the centre console next to the stereo holder? I have an iPhone6plus so i'm just worried it would interfere with changing gears being so bulky or also making it difficult to use radio controls.
Re: RHD Phone mount
Posted: Thu Jun 16, 2016 11:21 pm
by Snowmotion
I have the (holdmyphone/clicon/Brodit depending on country) mount that clicks on next to the stereo with the adjustable iPhone 5/6 holder.
For me it is a good fit and does not get in the way of a standard height shifter nor does it stop me adjusting the stereo.
I can post a pic later tomorrow if you would like.
http://www.holdmyphone.com.au/mounts/car/mazda/mx5/mx5-98-05.html?mode=grid
RHD Phone mount
Posted: Thu Jun 16, 2016 11:48 pm
by cruro02
About to install the Brodit unit for my iPhone 6s Plus over the weekend. A quick test last night looked like it will be spot on. Bought the powered mount but swapping the supplied cable for a standard Apple usb cable and running it back through the to the Pioneer AVH-X8850BT head unit so I have CarPlay functions.. As it happens my first two mods to my recently acquired 2009 PRHT..
Sent from my iPad using Tapatalk
Re: RHD Phone mount
Posted: Fri Jun 17, 2016 12:38 pm
by kalt
The unit looks reversible, ie rotate it to mount the other side of the console?? You want to mount it in the passenger side footwell, correct?
I been thinking of getting CD slot phone mount since playing CD's has become redundant on my Sony MEX headunit.
None of the slot mount units available on the market appeal, each have fundamental flaws and too much clunky plastic.
Might rub my hands together and get MacGyverated, then fashion something out of some balsawood, chewing gum and half an apple.
Re: RHD Phone mount
Posted: Sun Jun 19, 2016 8:51 pm
by guss_bruss
Snowmotion wrote:I have the (holdmyphone/clicon/Brodit depending on country) mount that clicks on next to the stereo with the adjustable iPhone 5/6 holder.
I would like picture if it's not too inconvenient? I haven't ever seen the iphone 6 with the cradle i think you are talking about which is the one i want but for the iPhone6s. Thanks! also if the mount allows can you please show a picture of it in landscape as well?
kalt wrote:The unit looks reversible, ie rotate it to mount the other side of the console?? You want to mount it in the passenger side footwell, correct?
They stopped producing them sadly! i have looked at those CD ones but I don't think a CD slot is meant to hold the weight of a phone out the front of it i wouldn't be surprised if it damaged the CD player internally
