still have overheating problems
- rossburns
When the weather is cold the temp gauge barely gets off cold, on hot days on a steep climb or cruising at 100 kph, it wants to boil, have changed thermostat and flushed system, radiator looks fine, hoses ok and new coolant. Don't know what to do next
- ManiacLachy
Re: still have overheating problems
Is it actually over heating, or is the gauge just saying it is? The dummy gauge fitted could be faulty
losing coolant?
done a compression test?
- rossburns
def not loosing coolant and gauge is fine, and yes it is getting hot, haven't done a compression test yet
- smy0003
Timing is all fine?
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
- rossburns
advanced 15 deg I believe
- NitroDann
maybe its retarded rather than advanced
rad cap still holding specified pressure?
- bruce
- Vehicle: NA8 - Turbo
Radiator looks fine.
Maybe the rad is not fine. I'd take it to a rad shop to do a pressure test and have a look.
- rossburns
yes will have to bite the bullet and get it tested, ahhhh more money !!
- zero00
Hope you get it sorted Ross
Roger D-SUNSHINE COAST
