[NA] Help me find the water leak!!
mitch_f1
Postby mitch_f1 » Sun Jan 17, 2016 4:02 pm
Hello,
So following all the rain Sydney has had recently apparently I've developed a leak, but I can only identify it from the mouldy smell; I cannot find damp anywhere! I have pulled all the carpets out (except the floor carpet) to look for any sign of moisture and I have probably sniffed most of the carpet as well, and cannot find it anywhere.
I've checked the usual culprits; soft top drain holes, sill drains, holes in roof etc but nothing.
Any help is appreciated, because after a day in the sun the smell is pretty wicked (not a good wicked either).
greenMachine
Re: [NA] Help me find the water leak!!
Postby greenMachine » Sun Jan 17, 2016 6:52 pm
It's not a coolant smell is it? Check around the top of the transmission tunnel, up close to the firewall. Heater cores are a known troublespot, and can sneak up on you. One way to tell is to watch your coolant level, a leaking heater can lead to regular small top-ups.
If that is what it is, it is a PITA to fix, but it needs to to be fixed quickly. Do a search, there are at least a couple of threads on finding and fixing this problem.
Check under the quarter windows in the doors, I have had leaks originating in the 3-way window/softtop/windscreen rail join.
Good luck
:mrgreen:
Postby 93_Clubman » Sun Jan 17, 2016 7:11 pm
Also check inside the doors as well as the sills below the doors, but reckon it might still be in the underlay/sound deadener below the carpet. It's not always apparent as the carpet has a backing that prevents some moisture getting through. Btw, check the ECU & ECU plug is dry - it's under the carpet in the passenger side foot well near the firewall.
mitch_f1
Postby mitch_f1 » Sun Jan 17, 2016 7:25 pm
Not coolant smell, and not damp in that area.
I have pulled up the carpet where I can and the sound deadener is dry. I will try look inside the doors
smy0003
Postby smy0003 » Sun Jan 17, 2016 7:29 pm
Inside the boot maybe?
Boot seal may have given up.
Could also be the foam in the white heater thingy behind the dash. Mine didn't smell too great when I got the car, so I cleaned it out when I removed the dash.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
mitch_f1
Postby mitch_f1 » Sun Jan 17, 2016 7:34 pm
Not boot; it's try and smell free. I doubt it would be the blower/heater assembly because the cowel drains are unblocked and there is no way for the water to get in there otherwise. Also I rebuilt and sealed the heater core not long ago, so couldn't be that.
Postby 93_Clubman » Sun Jan 17, 2016 7:35 pm
mitch_f1 wrote:I have pulled up the carpet where I can and the sound deadener is dry. I will try look inside the doors
Does tend to go to the lowest & hardest to access areas - don't forget the sills that run along each side of the car above the pinchweld.
mitch_f1
Postby mitch_f1 » Sun Jan 17, 2016 7:38 pm
I have already cleared the drain holes from the sills, and can confirm they flow fine.
ndragun
Postby ndragun » Fri Jan 22, 2016 5:24 pm
If its anything like mine, in heavy rain water drips from the seal at the top of the window onto the side of the seat bolster - and that's what smells.
That's for me anyway... so it could be the seats?
Even now, after having completely re-built the interior of the car and freshened all the carpets, i still have the funky old cloth seats - and that's what smells...
1994 MX5 Clubman
XIDAs, Wilwoods, 6ULs
