NB SE lock issue
Posted: Fri Sep 18, 2015 1:15 pm
Hi Guys,
not sure if this should go here or in the Electronics section...
I'm having issues with my passenger central locking (04 NB SE)... it will unlock but not lock. funny thing is the other key fob doesn't unlock it but I've found it can be a little random too but when it does work it only unlocks the door.
I suspect it's the actuator.. which is quite a pricey item I've since found it :/
I have read somewhere that it could also be due to the bars that actually move when the central locking is activated...
anyone have any suggestions that I could try to fix it? Could it just be key programming? I'm going to take the door panel off and have a look when I get time in the hope it's something silly stopping it from working correctly...
also would any NB left door actuator work in it's place if I were to replace it?
thanks in advance for any help
Brad
Brad
