Hardtop side brackets?
RS2000
Postby RS2000 » Mon May 18, 2015 9:55 am
My hardtop stays on permanently, as it is a track car.
Is there any benefit in replacing side latches with Jass Performance brackets?
Or waste of money?
Re: Hardtop side brackets?
Postby Magpie » Mon May 18, 2015 10:19 am
Yes there will be no movement in the latches.
Magpie wrote:Have a look at this thread http://mx5cartalk.com/forum/viewtopic.php?p=723899#p723899
orx626 wrote:The results are in! :!:
Mazda factory hard tops do increase the beaming and torsional stiffness of a standard MX-5 chassis! :P
RS2000
Postby RS2000 » Mon May 18, 2015 2:24 pm
Thanks Magpie, I had read that a while back.
Automotive Plus state that for any structural benefit, each latch must apply a clamping force.
Wouldn't adjustable factory side latches do that better than Jass brackets (just flat plate)?
Dweezle
Postby Dweezle » Mon May 18, 2015 2:28 pm
My Jass plates actually straighten as you tighten them and seem to apply a clamping load.
I was quite impressed.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby Magpie » Mon May 18, 2015 2:37 pm
I agree on the Jass as sold by Omgpham (I have these). These 'pull' the hardtop into the same position as the OEM latches, there is still a little tweaking to be done with the Jass but once it is tightened it is very solid.
Garage Star (also sold buy Omgpham) requires you to position the hardtop correctley first then 'lock' it down.
Dehamsta
Postby Dehamsta » Mon May 18, 2015 3:44 pm
I've got the jass brackets and they are fantastic for keeping the hardtop on tight with virtually no squeaks. Much better than the oem latches.
