So, the Jaffa was parked out in Brisbane's heavy rain on Friday. Result - a car with wet carpets, and the bonus was the water got under the breaks in the clear coat on the bonnet and the tops of the guards and bubbled it, so it's royally frakked.
I am intending to get the bonnet and guards repainted at some point, but was thinking through how to make it not look like total arse like it does at the moment. I had thought about plastidip, but then remembered vinyl wrap - better solution for me as I hate painting type activities. Might be cool to run a matt black bonnet for a while.
Main thought was do the bonnet first. Any ideas on prep? Do I want to try and get the surface as smooth as possible and get the clear coat off, or will the wrap simply go over it and smooth it out?
Bubbling clearcoat, rain and vinyl wrap
- Vat
'98 Evo Gold NB8A
QR-Clubman 66.5109|Sprint 63.3635|Sportsman 67.4673|National 92.3481|Lakeside 65.7478|MP K 1:35.382|MP E 1:16.422|NM 1:08.017
Re: Bubbling clearcoat, rain and vinyl wrap
You'll need to get it really smooth - so sand and claybar!
I had to cover up some marks and holes on my Integra (replaced the wing) and it is visible, but less so as I used CF-look vinyl.
That said, if you are looking to re-spray, then I assume the rest of the car isn't great...so, balance out the effort - no point going for a pro finish if the rest of the car looks crap.
- Vat
Actually, it's not too bad from the A pillars back, I was just going to colour match (not going for showroom here) when I got the bonnet and guards painted.
Thanks for the advice. What grade sandpaper do you think?
'98 Evo Gold NB8A
Vinyl wrap will not adhere to undercoat or sanded surfaces
Vinyl wrap relies on high surface tension same as window tint .
- bruce
- Vehicle: NA8 - Turbo
So vinyl wrap won't adhere to grey primer?
lizard wrote:Vinyl wrap will not adhere to undercoat or sanded surfacesVinyl wrap relies on high surface tension same as window tint .
Really? Where did you get that from? In that case, why is the vinyl is sticking to my sand, puttied, partly primed hatch?
bruce wrote:So vinyl wrap won't adhere to grey primer?
Vinyl wrap has a very thin layer of adhesive and any matt/dry surface will suck up the adhisive .Have you seen big air bubbles in wrap ? this is where the adhesive has let go of the wrap and bubbled . May not happen strait away but give it a hot day then
- Vat
Surely if you sand it down with something like a wet 2000 grit paper and then run a clay over it the surface will be smooth enough for the adhesive to take? That's pretty much what I was planning.
'98 Evo Gold NB8A
Vat wrote:Surely if you sand it down with something like a wet 2000 grit paper and then run a clay over it the surface will be smooth enough for the adhesive to take? That's pretty much what I was planning.
Up to you
Why would you ever use a clay bar
- Vat
lizard wrote:Why would you ever use a clay bar
If you're trying to be helpful, why not phrase that as "I wouldn't use/there's no need to use a clay bar because..."? Combination of force of habit and ensuring the surface is smooth and free of contaminants, particularly the remnants of the sanding.
'98 Evo Gold NB8A
Vat, it's a temporary fix. If you are planning on painting the car in the next 6-12 months...it's probably not going to be a big deal. Even if it bubbles off, you can do a quick fix.
Do you have patches with no clearcoat? If so, you won't get rid of the edges where clearcoat meets no clearcoat. This edge will be just as noticible under the wrap.
- bruce
- Vat
RS2000 wrote:Do you have patches with no clearcoat? If so, you won't get rid of the edges where clearcoat meets no clearcoat. This edge will be just as noticible under the wrap.
Thanks, that was what I was wondering - I need to basically sand the clear coat off and get a smooth surface.
Was initially thinking the plastidip route but judging by a couple of experiments with clear plastidip you still get the aforementioned edges showing so prep would be the same, and the prospect of 'painting' an entire bonnet with the stuff sounds like a colossal pain in the rear (don't really have a great environment to do that sort of stuff), particularly compared to wrapping it.
'98 Evo Gold NB8A
- bruce
Easiest and cheapest option is just rattle can it black.
Plastidip can get expensive, and wrap sounds very fiddly.
