If so, does that mean you can use those holes to bolt a number plate on, like this one?
(In other words, is that how it's been done in the second image, using pre-existing holes? Maybe longer bolts?)
Regie wrote:if you mount the plate like the second pic, you will have some big holes left in your bumper.
That second pic has had the holes filled and repainted.
PAU61L wrote:Good morning everyone
Option 1 remove number plate and cut plastic mounting base, so that it is smaller than number plate and refit number plate
Option 2 remove number plate, remove mounting base by drilling out two rivets, remove captive nut clip off mounting base, cut them so that they can be inserted into the big holes in bumper, make the captive nuts as long as possible an skinny enough to fit it hole, attach bolt slide behind bumper through the hole, remove bolt gently, it will stay in place because of foam behind bumper, then gently screw number plate onto bar. Very neat and less likely to catch leg on number plate.
Paul
Mr Morlock wrote:A mesh grille will reduce airflow in my opinion and is not a modern look. In theory you can mount a number plate in the grille opening but that also raises the question as to whether it has any negative affect on cooling.
