AGI Precision Rollbar Installation Problem
Posted: Mon Nov 17, 2014 8:38 pm
by Dehamsta
Hi, this is more of a question to those who have installed an AGI roll bar.
The problem is the holes in the back stays (the largest ones) do not appear to line up with the holes i've drilled into the body above.
Anyone experience this problem and how did you resolve it?
BTW it's on an NA6.
Cheers peoples.
Re: AGI Precision Rollbar Installation Problem
Posted: Mon Nov 17, 2014 8:53 pm
by The American
Do you mean, the back stays towards the rear of the car, or the section directly behind the seat?
Posted: Mon Nov 17, 2014 8:58 pm
by Dehamsta
The American wrote:Do you mean, the back stays towards the rear of the car, or the section directly behind the seat?
The ones that are directly behind the seats. Sorry for the confusion I might of got the terms mixed up.
Posted: Mon Nov 17, 2014 9:24 pm
by The American
I found it pretty difficult to get the top and bottom holes aligned. In my case, I ended up enlarging the lower holes from below to allow the bolts enough movement to engage with the nuts welded into the plate. This was not an elegant solution!
Having a long series drill bit helped, but it was still very awkward.
Posted: Mon Nov 17, 2014 9:51 pm
by gslender
I agree it was pretty painful to install when compared to the mx5plus bar - I also didn't like the top bar so close to my head. Not safe for road use.
Posted: Mon Nov 17, 2014 11:11 pm
by chrons_rotary
I also had the same problem, had to enlarge bottom holes.
Also before you install the rollbar, make sure you replace your fuel pump if needed and any worn seatbelts before hand, as it is a PITA to take it out each time (i had a dying fuel pump and frayed seatbelts when i installed mine).
Posted: Tue Nov 18, 2014 8:31 am
by Dehamsta
I found that it helps to remove any seam sealer which prevents the feet from resting flatly on the bulkhead behind the seats.
Posted: Thu Nov 20, 2014 7:39 pm
by Dehamsta
I give up..gonna take it to AGI to finish the install. Hats off to those who install it themselves!
Posted: Sun Dec 07, 2014 10:51 am
by Dehamsta
Installed. Very happy.
Posted: Sun Dec 07, 2014 11:16 am
by gslender
How is your head? Does it hit the bar?
Posted: Sun Dec 07, 2014 11:55 am
by Dehamsta
gslender wrote:How is your head? Does it hit the bar?
Nope but it's about 10cm away from the bar. However, I'm not a tall guy ~173cm.
