my hard top is very sad looking and needs a colour change repaint. the outer window seal has shrunk and the seal joiner at the top has fallen off...
Whats involved in removal/refitting the window with a new seal. i understand that the outer seal can be replaced with a generic one (VR commodore?) but is the joiner available?
what about the inner seal? ive read its just a foam strip and sealed up with some windscreen sealant?
anyone with advice on refitting and sealing without using OEM seal??
Remove/replace hard top window.
- Vehicle: NA6 - Turbo
Re: Remove/replace hard top window.
PM lightyear (Dave) - he was the maker of the carbon fibre HTs & did a lot of research & work in this area.
Interesting that you just posted this i was just looking at these:
http://forum.miata.net/vb/showthread.php?t=477975
Though i would like to hear from Lightyear about if he does just the glass/acrylic/lexan replacement for the factory hardtop glass..
Cheers.
Cheers.
- Suspense
I just had mine replaced after repainting. It can all be done with standard stuff, a seal between the glass and the hardtop then the rubber moulding that sits on the outer side over the glass edge. Cost was $90.
Was the 90 using generic stuff or mazda stuff? 90 just for parts or was that drive in drive out?
- Suspense
$90 for the whole job done, standard window parts. The Mazda rubber moulding part alone is $130 (not the seal) for what is a standard shape.
