Best seat for agi roll bar nb
ryuhou
Postby ryuhou » Thu Jul 03, 2014 5:50 pm
Hi guys just installed the glass window agi bar and lost about 10cm of travel on my bride digo- was wondering what the best seat for comfort would be? Helmet clearance is not of concern at this point.
Cheers mike
ryuhou
Re: Best seat for agi roll bar nb
Postby ryuhou » Fri Jul 04, 2014 12:11 am
Anyone? How are the sparcos
tescoking
Postby tescoking » Fri Jul 04, 2014 3:00 am
I have the same problem, and I believed any sparco seat should be able to fit in, just make sure to tilt back the seat to where you like when you do the welding.
My 5
TTT
Postby TTT » Fri Jul 04, 2014 2:50 pm
NA6 here
NB glass window soft top
AGI roll bar
Sparco Sprint V on stock NA6 rails.
Top right corner of seat touches bar before sliding all the way back.
probably lost about 10cm too.
ryuhou
Postby ryuhou » Fri Jul 04, 2014 5:39 pm
Thanks guys Yeh i was at mania before measuring the sprint V same dimensions tbh. Look like need something with a narrower headrest region and mounted lower
Mayb similar to the Na stock seat which is shorter
TTT
Postby TTT » Fri Jul 04, 2014 9:26 pm
Next MX5 = different roll bar
Snowmotion
Postby Snowmotion » Fri Jul 04, 2014 10:50 pm
You don't loose any seat travel with the MX5Plus Roll bar (not the Tall Boy).
Sparco fitted and plenty of room for my 192cm.
ryuhou
Postby ryuhou » Sun Jul 06, 2014 12:39 pm
yeah im abit cut i didnt do my research properly aye - going to get a set of pci v2 mounts from the states - now which seat...
TTT
Postby TTT » Sun Jul 06, 2014 7:24 pm
for visual purpose..
NA6
NA6 rails
Sparco Sprint V
AGI bar
I'm 5'10" (178cm ish)
II you've already bought the it I say sell bar to someone who is going to bolt the seat to the floor for track only and get a Brown Davies or Mania or MX5 + ones.
