Quick question - Factory underbody brace
Sage
Postby Sage » Wed Jun 11, 2014 5:03 pm
Hey all i have a 1991 mx5 without any factory bracing.
Just wanting to know what car is suitable for a donor? I believe anything upto 1998 though im not sure..
Can someone please confirm i can fit bracing off any 1993-1998?
Thanks very much!
this is the pic of what i am talking about :)
MrRevhead
Re: Quick question - Factory underbody brace
Postby MrRevhead » Wed Jun 11, 2014 5:12 pm
Sage wrote:Can someone please confirm i can fit bracing off any 1993-1998?
Yep, no a problem, identical chassis across all the NA's (although, NA's ended in 1997).
Sage
Postby Sage » Wed Jun 11, 2014 5:38 pm
ncie one mate. thanks for the quick reply!
Skinny Jim
Postby Skinny Jim » Wed Jun 11, 2014 6:12 pm
your old subframe probably won't have those tabs welded on tho.... you'll need to add them
taminga16
Postby taminga16 » Wed Jun 11, 2014 11:58 pm
Search the big forum, I seem to recall someone DYI fabricating some of these.
Greg.
lightyear
Infinity & Beyond
Postby lightyear » Thu Jun 12, 2014 8:56 am
Early cars won't have the right subframe to be able to bolt them on. By all means put braces on your car if your goal is to make your car heavier, and spend some money.
plohl
Postby plohl » Thu Jun 12, 2014 9:14 am
The NA6 chassis is also missing the mounting points at the front of the brace. The effort to put the bracing on seriously outweighs any benefits you may/may not get from it.
plohl
Sage
Postby Sage » Thu Jun 12, 2014 9:16 am
damn.. looks like i asked the right people! i wont bother then.. :) thanks again guys!
TTT
Postby TTT » Thu Jun 12, 2014 11:17 am
perfect opportunity for you to buy this..
viewtopic.php?f=44&t=63881
Sage
Postby Sage » Thu Jun 12, 2014 4:12 pm
is that a flyin-miata one? mild steel? can i weld it rather than bolt it? :)
