Weather strip problem need help
Posted: Wed Mar 05, 2014 10:35 pm
by tescoking
Hey guys, can someone tell me what could causing this? I suspect that the door had been damaged by the previous owner before but of cause I don't want that is truth. So please help me out guys.
Re: Weather strip problem need help
Posted: Wed Mar 05, 2014 10:38 pm
by aka_juffa
The weather strip is a replaceable part. Pull the inner door card off and see if you can re-seat the weather strip.
J
Posted: Thu Mar 06, 2014 12:01 am
by wassup
Problem is caused by a broken clip which is visible in your first pic. There are 4-5 of these that run the length of the strip. You can see the little square part in the middle, that is where you press in with something like a flathead and the clip releases allowing you to lift it up and out when replacing. The little tab in the middle is probably broken due to age.
I'm pretty sure you can buy these clips separate (for a few dollars) rather than paying $120 for a pair of strips
Edit
http://www.ilmotorsport.de/shop/article_detail.php5?aid=1280&oid=12&depth=0&page=4&count=65&PHPSESSID=5d2e12750364261aa473938f4e953f9c
Posted: Thu Mar 06, 2014 12:19 am
by tescoking
I have bought the new clips to replace it as well, but it just doesn't work.
Only the yellow one is old, all the white one are new.
Posted: Thu Mar 06, 2014 4:41 pm
by tescoking
Hey guys, the clips and strip are new, but it is still popping up, please give me a hand on this.
Posted: Thu Mar 06, 2014 4:58 pm
by StuwieP
tesco the rubber at the end of the strip folds down aorund the door and seats in the door jam/where the door closes.
Is the clip oriented correctly?
edit: the strips are fairly soft, are you sure it's not damaged?
Posted: Thu Mar 06, 2014 5:03 pm
by tescoking
StuwieP wrote:tesco the rubber at the end of the strip folds down aorund the door and seats in the door jam/where the door closes.
The strip is not soft, it is very hard and I can't get it "stick" on the door
Posted: Thu Mar 06, 2014 6:25 pm
by tescoking
Problem solved, replace the yellow clip to white clip and using 7 clips instead of 5, weatherstrip now will not pop up although there are a small gap between it to the door.
