NA ELECTRIC WINDOWS
zero00
NA ELECTRIC WINDOWS
Postby zero00 » Tue Dec 31, 2013 11:57 am
Just went to raise the electric windows in my NA and they decided not to operate, both sides. Could this be a fuse and where is the fusebox located?
Had been operating fine 10 minutes earlier
Thanks
Roger D-SUNSHINE COAST
jimmy_vee
Re: NA ELECTRIC WINDOWS
Postby jimmy_vee » Tue Dec 31, 2013 12:40 pm
The fuse is above the drivers kick panel, if you have an import look for this text.
(パワーウィンド)
30A
zero00
Postby zero00 » Tue Dec 31, 2013 1:07 pm
jimmy_vee wrote:The fuse is above the drivers kick panel, if you have an import look for this text.
(パワーウィンド)
30A
Thanks Jimmy - not sure what that means but will look there :wink:
Postby Okibi » Tue Dec 31, 2013 10:31 pm
Nice work Jimmy
zero00
Postby zero00 » Wed Jan 01, 2014 2:46 pm
Thanks guys, cruised down to 'Pirates' place after coffee this morning, he found the fuse box near the kick panel, my neck prevents getting in at that angle but a 'remove and re-insert' of the fuses under the bonnet and all is working well again
Thanks again to all - appreciated!!
