Had a bit of a poke around the net to no avail. Looking for some aftermarket guage faces for my NA that aren't hokey looking white ones that look like they are from 1994.
Something retro looking to match my KG Works panel.
Many Thanks,
Jeff
Aftermarket NA Guage Cluster Dials
- Vehicle: NA6 - Turbo
Re: Aftermarket NA Guage Cluster Dials
You will get no better service than to use http://revlimiter.net/ if your are after custom guage faces.
These are mine, I requested the blue to match the outside of the car, at night they are very easy to read. They are based on the http://revlimiter.net/store/gauges-f1.php with custom colour and needle positions. I wanted 7,000 rpm at the 12 o'clock position, so wherever the zero RPM worked out the zero kmh started from the same place:
Champion,
I don't know why I couldn't find that myself.
Many Thanks,
Jeff
Many Thanks,
Jeff
- meanmx
I second revlimiter. Not only does he have some great designs but he is also superb to deal with
2014 VW Mk7 Golf R
Ordered. Many Thanks.
- slug_dub
RevLimiter has superb designs equal to the great designs that KG Works and RS Products make from Japan... you can still get those though...
check in with Rev 9 Autosport, R-Speed and Miataroadster.
Glad you got what you wanted. For retro I had this set...
NB SE, NA 1.8.
- D.A.M
trader wrote:Glad you got what you wanted. For retro I had this set...
where did you get that cluster from???
If I had an NA, I'd rock this AWD cluster despite the hideou$ co$t:
See http://www2s.biglobe.ne.jp/~AWD/m1normal.html
Unfortunately they don't make it for the NB.
- Vehicle: ND - Turbo
D.A.M. some guy from Canada makes them and sells on ebay (or used to).....labour intensive using three layers of laminated paper to get the right effect. Never looked right on my yellow car but would look great on red especially with chrome centre caps.
NB SE, NA 1.8.
