I have ignored this for a while - left the clear plastic sheet on when I removed the door trim and used race tape to cover over any exposed black goo.
Has anybody successfully gotten rid of this gunk? How and with what?
Gets on everything. Thanks!
Removing black goo on inside of door trims?
- MrRevhead
Re: Removing black goo on inside of door trims?
WD40 & turpentine works well in removing it, also throttle body/brake cleaner.
But try the WD40 or turps first as they are not as strong/damaging to the paint.
- Suspense
That stuff gets everywhere if you don't watch out. I got it off my hands and various places inside at home (it gets everywhere!) with metho.
Thanks guys went with a combo of wd40 and turps. Works wonders. Still a bugger to get off though, horrible stuff.
- MrRevhead
It's a job worthy of shaving the hair off your arms and legs....when that goo gets on the hair it's a bugger to get off! lolmazmad wrote:Thanks guys went with a combo of wd40 and turps. Works wonders. Still a bugger to get off though, horrible stuff.
Glad the recommended solvents worked!
- Jeo
Wax & grease remover works a treat too.
It is one pain in the %#{{} job isn't it? I got most of the drivers side, haven't started the lhs.
