paint repair/detailing products
TTT
Re: paint repair/detailing products
Postby TTT » Thu Oct 03, 2013 9:41 am
waxit.com.au
everything you need.
email them, tell them the car, possibly pics of the damage and they can suggest the correct types of Pads and polishes to use and in what order.
They sell orbital polishers too.
one stop shop.
wassup
Postby wassup » Thu Oct 03, 2013 10:02 am
Not sure where you're located but ditto the above for Car Care products.
If you're in Sydney you can drop in and the guys will only be too happy to inspect your car and give you some advice.
As a starting point you'll need:
2 buckets, one with a grit guard
Microfiber wash mitt
Ph neutral detergent
Microfiber drying towel (waffle weave type)
Clay bar
DA polisher
APC to clean wheels, engine bay etc
A DA is the only way to effectively remove swirls. The right pad and compound depends on the condition of your paint. The above kit will help you maintain your paintwork for 8-12 months before you need to do it again.
Good luck!
1990 NA6
Civic Type R
