My next tool: The Professional Nibbler
Postby Lokiel » Sun Aug 25, 2013 12:16 am
This is probably going to come across as an advertisement but it's very impressive and easy to use so I'm sure that others may be interested in it.
I'm planning to make a cold air box from thick aluminium checkerplate which requires the cutting of curves and a circular hole for the air filter's hose/pipe.
Cutting out circles with a jigsaw/dremel/files is a lot of work and it's much better/faster to use a holesaw but these are expensive for what will most likely be a one-off use.
The same goes for cutting curves, if you're anal like me, you end up spending a LOT of time with a file to get it right.
I found the "Professional Nibbler" after a few web searches which looks ideal for these types of jobs and will definitely be used more than once:
It attaches your drill and:
"The Professional Nibbler can be used free hand or bench mounted. It will cut mild steel, stainless steel, colour bond and corrugated iron quickly.
On colour bond (corrugated iron) it will not scratch the paint, no sharp edges, and no sparks. It doesn't generate heat so rust will not occur unlike when using the grinder.
That's why it's widely used by plumbers, roofers, car restorers and the DIY sector.
The Professional Nibbler allows you to cut guttering, trim deck, mini orb and car body work with ease. You can cut out internal holes for down pipes, sky lights chimney flutes and more. You start in the middle of a sheet, drill a 10mm hole, place the head of the Nibbler in and start cutting away."
See http://newstyledirect.com.au/Professional-Nibbler
There's a video link on the page.
It's Australian made too!
Apu
Re: My next tool: The Professional Nibbler
Postby Apu » Sun Aug 25, 2013 6:15 am
Have you used it? I saw this on TV but ended up buying an air dríven one...wasn't quite so easy and it had a bit of pull and didn't turn quite as easily as I thought. And it spat the bits everywhere...sharp too!
Postby Lokiel » Sun Aug 25, 2013 7:38 am
Not yet, hoping for feedback like yours.
I have a hand/manual nibbler and that always produces crap results unless you take very small "bites" but that takes forever and you still need to do a lot of filing to smooth the edges.
I was impressed with the video but do take it with a grain of salt since it looked so effortless. This nibbler has a very large handle which I assume is necessary to achieve the desired curves and I suspect it's probably best used when clamped to a bench.
MINX
Postby MINX » Sun Aug 25, 2013 7:43 am
I bought this one couple of years back
You are welcome to borrow it to try
It works but it pretty trickey to get smooth result
Maybe just lots of practice
TieNN89
Postby TieNN89 » Sun Aug 25, 2013 3:02 pm
how thick is the stuff you're trying to cut?
