Fix surface fade carbon fibre ducktail spoiler
sydneyrace
Postby sydneyrace » Thu May 23, 2013 8:15 pm
Hi All, I have a faded No Pro carbon fibre rear ducktail spoiler. It has white spots all over it. Can anyone recommend a repairer around the Parramatta area and how much this may cost? Thanks in advance for your help.
Re: Fix Carbon Fibre wing
Postby NitroDann » Thu May 23, 2013 8:21 pm
Thats totally a vanity spoiler.
The thread title lead me to believe the thread was about a cracked carbon wing.
maybe change it to include surface finish.
sydneyrace
Re: Fix surface fade carbon fibre ducktail spoiler
Postby sydneyrace » Thu May 23, 2013 8:40 pm
Thanks, Dann. Subject line updated now.
deviant
Postby deviant » Thu May 23, 2013 11:29 pm
From what I understand that is basically the surface finish failing work UV damage and allowing moisture in. Probably not much you can do about it.
Postby Regie » Fri May 24, 2013 8:27 pm
talk to Guy_Coles. he has the same problem with his carbon side skirts.
Pretty sure there is nothing you can do about it
narita
Postby narita » Fri May 24, 2013 8:31 pm
Wax it and then clear coat.
WINTON PB - 1:57.4000
sydneyrace
Postby sydneyrace » Sat May 25, 2013 11:05 pm
I have tried waxing it but the spots will not come out. Researched that a cut, polish, and clearcoat may be the solution. I have asked the Touch Up Guys to do this. Hope they can do a great job. Unfortunately, can only be done next weekend.
Guy_Coles
Postby Guy_Coles » Wed Sep 11, 2013 3:59 pm
Without seeing it up close it sounds like spotting or clouding in the gel coat. That's rare for NoPro stuff as it's normally excellent quality but I have the same issue with a Burnout side skirt but far more excessive. Depending on how deep it is, you might sand it back and have it sprayed with a UV resistant clear coat. Mine are past that and I've been forced to have a layer of CF applied over the top and then have multiple layers of clear on top of that.
2006 Black NC Soft Top with lots of Mods -
WP: 1:12.26 , SMP South 1:106.25 - 11th outright in Victorian 6 Hour 2015
http://privasec.com.au//
JT3
Postby JT3 » Wed Sep 11, 2013 11:07 pm
Just by having a look at that pic you attached, it looks like the clear coat has gone bad.
Try this out as I know many of the Evo guys have had success restoring their carbon spoilers
http://forums.evolutionm.net/evo-how-to ... wings.html
Evo 7
Mira L200
MX5 NA
Users browsing this forum: No registered users and 177 guests
