I've read low grit sand paper and touch up paint. As well as rust converter/treatment but read up that isn't great. Need some help please
Regie wrote:spending my money again Trevor
sailaholic wrote:Unless you have panel experience (which I'm guessing you don't by the question) get it fixed properly by a professional or it is likely to look like crap and grow like the cancer it is.
Also look at why is there, rust in modern Japanese cars is not common without an underlying problem.
sailaholic wrote:So it's just tiny? Just surface rust no bubbling etc?
If so you will probably get away with a home repair.
93_Clubman wrote:Ah it's on the edge at the end of the door. You should be able to DIY that - the concern was that it was on a flat outer surface, which with metalic(?) paint wouldn't necessarily be easy for a novice DIYer to fix to a sufficiently high standard on a six to seven year old car. At the least you should be able to DIY something that will stop it from getting any worse.
Basics should be in these:
viewtopic.php?f=57&t=46454&start=45
viewtopic.php?f=76&t=47880
viewtopic.php?f=76&t=55059
