Can you replace a glass soft top window
mx5002
Postby mx5002 » Fri Apr 26, 2013 3:54 pm
Broke mine :-(
Can you get a replacement or am I up for a new top?
Hate doing a two man job on my own :twisted:
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
itrungs
Re: Can you replace a glass soft top window
Postby itrungs » Sun Apr 28, 2013 2:15 pm
You should be able to replace the soft-top window.
You have a few options, remove the broken glass and glue a new one in (I'd recommend getting this done by a professional to avoid any leaks.
You could also cut out the vinyl around that area and sew a soft-top glass window with the vinyl attached around it (cut from another soft-top).
I have a spare glass window with a demister if you're after a cheap replacement window with a section of vinyl around it.
