Also found this at Bunnings, Bear Outdoor Mounting Tape. It doesn't mention how heavy it will hold, but does say it's strong enough to stick number plates, reflectors and badges on cars.
NitroDann wrote:Id drop into a body shop and grab some/give 6 pack to have them do it.
shuey wrote:.. true, but thought of giving it a go and see how I fare. May just buy it off eBay if I can't find one tomorrow
Crapweasel wrote:
Get another SE alongside if possible so you can measure seven times before fitting!
I'd be paranoid as hell doing this, just a couple of mm off and it'll look out of place.
If you're a braver man than me with a keen eye for detail, then good luck, and post pics once done!!
Regie wrote:3M VHB is what you are after. I might have some spare stuff here shoot us a PM
Mr Morlock wrote:3M make great products but are not always easy to buy . Even attaching it to a boot still means maybe down the track it has to be removed and a strong d/sided tape can be difficult to remove. It adds weight to the boot ( the spoiler) and probably affects boot closure and does nothing. The picture appears to show a stud which is probably dríven into the moulding ie a double ended stud- in all likelihood a self tap thread albeit 10 12 or 14Gauge -under the rubber washer there is probably a metal washer which is integral with the stud either made by cold heading or even turned. In theory it can be screwed out but another possibility it is moulded in situ. In any event I would not remove the stud. The stud is there for a purpose eg to attach the spoiler. If you are really hell bent on attaching the thing to a perfectly good boot then the right way looks to be drilling a hole and attaching it for a firm fit.
narita wrote:Hi shuey,
Have you considered sawing off that god awfull screw and using sikaflex?
