Help i cant get nb tail lights out
initial D
Postby initial D » Fri Mar 08, 2013 11:41 am
Trying to take NB8A tail lights out and put in NB8B tail lights i toke out all the bolts and its loose but doesn't wanna come out?
Kenstaki
Re: Help i cant get nb tail lights out
Postby Kenstaki » Fri Mar 08, 2013 11:57 am
How many bolts/screws have you removed?
I did it recently on an NB8A, from memory:
There's 2 nuts to remove that are sitting horizontally and 1 screw sitting vertically.
Then you need to jiggle the light assembly out. You may have to push sideways on the light, it may not go out in a straight line.
After thought: Have a look at your new NB8B tail light assembly to work out how it slides out.
Suspense
Postby Suspense » Fri Mar 08, 2013 12:40 pm
If you're 100% sure you've taken all the bolts out, then give it a firm whack. They tend to get stuck in place if they haven't been removed in a long time/ever.
initial D
Postby initial D » Fri Mar 08, 2013 1:02 pm
Hey yeh i got the sucker out but the indicator light socket was a bit different using the same wiring as nb8a but i manged to fit it in a angle looks good.
