Is there a chemical that makes the water slide off rather than bead up like Rainex does?
Come to think of it, it would be good for side windows too....
Silvia wrote:SIGH!![]()
why am I so misunderstood![]()
Windscreen is fine.Rainex is wonderful
My rear window is obscured by waterdrops at any speed in the rain.
I'm looking for something to make those drops go away..
Silvia wrote:Yes of course I've used Rainex on the back window too - worse visibility, as more raindrops sit on the glass without enough wind to dislodge them apparently.
Hi Roger Did the "white GT86 January" in your sig. actually happen?
Rain still pissin' down here.
I tried the potato once - someone told me that's what the Spitfire pilots used - it was a bit yucky and when I washed it off things returned to previous .
No, I'm thinking the Morning Fresh could be the go - either as a run off effect being a surfactant, or making the glass very clean so nothing on the surface repels water or causes beading.
Who would have thought the answer was so elusive..
