Hard Top Stand from Howards Storage World
Posted: Mon Jan 14, 2013 11:17 am
Hi Guys,
Not sure if you're aware, but Howards Storage World is now selling flat packed hard top stands for the MX5
The only minor change is to get the horizontal bar to fit the base - you just need to cut a 1mm groove with a pair of snips about 3-4cm long so that you can squeeze the plastic edge into the hole at the base. Once the edges are in, a hammer/mallet will come in handy to put it securely in place.
The only things missing from this kit are a few pool noodles and cable ties. I'll include pics once completed (having troubles finding a black one).
The other thing I was thinking of was to fill the horizontal pipes in the base with sand so there's some extra weight at the bottom, I'll cable tie some weights from my old handweight set to hold the base firmly to the ground... I have rested the back of the stand against a rock wall so it should be relatively stable anyway but I want to be certain it won't fall over.
The Hard Top stand from Howards Storage World is on sale now for $50
