Wiper arm restoration help.
mx5lover
Postby mx5lover » Tue Dec 18, 2012 9:24 pm
Hi,all
My wiper arms are rusted, and looks uglily. I saw a post about restoring the wiper arm two months ago,
but I can't find it now.
I am going to paint the wiper arms this week, but I am newbie.
So what kinds of sand paper and paints should I use?
Thanks.
M1474
Vehicle: ND - Turbo
Re: Wiper arm restoration help.
Postby M1474 » Tue Dec 18, 2012 9:36 pm
I just did mine.
I sandblasted, cold galvinised, and dulux gloss black from a rattle can. I wish I had used a matte finish.
Too bloody fiddley to sand with paper unless you really enjoy sanding.
GHETTOCET
jordy94
Postby jordy94 » Tue Dec 18, 2012 11:11 pm
mx5lover wrote:My wiper arms are rusted, and looks uglily.
Thanks.
Depends on how rusted they are. Light surface rust can just be sanded away with 320+. Don't use anything too aggressive on the metal as scratches may transfer through the paint.
If it's heavy rust, just get new wipers
Postby Mr Morlock » Wed Dec 19, 2012 12:23 pm
a lot of these things are not worth doing ie more time and effort than they are worth. Suggest check what replacement arms cost. Painting is always the same story prep sanding, probably a prime and then a top coat eg epoxy black but you can soon rack up $30. I am not even sure if the originals are painted- there is a good chance these are zinc coated with black/ satin passivate. You can approach painting by asking a paint specialist eg Body Shop or you can do a bit of reading- there are lots of books on auto painting- even check out SCA.
Apu
Postby Apu » Wed Dec 19, 2012 1:44 pm
I just sanded and sprayed mine matt black. On the Integra I used Plasti-Dip.
I think going the whole hog is a bit over the top...despite having had the car resprayed.
mx5lover
Postby mx5lover » Thu Dec 20, 2012 7:58 pm
Thx guys.
I have checked the replace arms,mania got them for $30, but they don't come with the part which attached to the car.
Mr Morlock wrote:a lot of these things are not worth doing ie more time and effort than they are worth. Suggest check what replacement arms cost. Painting is always the same story prep sanding, probably a prime and then a top coat eg epoxy black but you can soon rack up $30.
Just like you said, the prime + epoxy black is nearly $30 at autobarn, but I would like to try it, get some experience of painting, that I can paint my wheel later.
Apu
Postby Apu » Thu Dec 20, 2012 8:36 pm
You can get a self priming matt for about $15.
Postby hks_kansei » Fri Dec 21, 2012 8:23 am
Sand off the rust with ~400grit
If you don't mind the finish left, then prime and paint (look into some rust converter too so it simply doesn't bubble through the paint after 6 months)
If you don't like the sanding marks from the 400, sand again with 600-800grit before paint.
Postby 93_Clubman » Fri Dec 21, 2012 10:33 am
Did mine a couple of years ago - fortunately no surface rust, so just cleaned & sprayed with 310g can of White Knight Squirts Quick Dry Flat Enamel in Flat Black, of which 50% left. Both wiper arms still look like new.
wassup
Postby wassup » Fri Dec 21, 2012 2:56 pm
I think it might have been my post
http://mx5cartalk.com/forum/viewtopic.php?f=57&t=49130&start=75
I agree with other comments made. It really depends on the condition of the wiper arms. If you check my post youll get an idea of the condition of mine and how they came up using wetsanding and Matt spray paint from SuperCheap Auto.
1990 NA6
Civic Type R
Hambag
Postby Hambag » Sat Sep 07, 2013 5:54 pm
Hey guys, does anyone know the best way to remove the plastic trim around the wipers? Being 20som years old its quiet brittle so I want to take it lightly..
PhilM
Postby PhilM » Thu Sep 12, 2013 6:10 pm
+1 I need to remove the plastic cover in front of the windscreen as well - having trouble removing the little covers which are brittle, the 1st one i tried cracked.
Rosso Corsa Red NA V Special
wassup
Postby wassup » Thu Sep 12, 2013 6:23 pm
Hambag wrote:Hey guys, does anyone know the best way to remove the plastic trim around the wipers? Being 20som years old its quiet brittle so I want to take it lightly..
You said it yourself. Being 20+ years old with uv damage its pretty well documented that removing the cowl will result in damage.
Others have had some success with jewelry screw drivers
http://forum.miata.net/vb/showthread.php?t=58684
May as well buy those overs (3-4 bucks each at mania) and worry about not breaking the cowl which will set you back $244!
Let us know how you go
1990 NA6
Civic Type R
Postby 93_Clubman » Fri Sep 13, 2013 11:39 am
wassup wrote:Others have had some success with jewelry screw drivers.
Yeah, a jewelry screw driver is what I've used - just do it somewhere you won't lose the cap as they can fly off.
Hambag
Postby Hambag » Fri Sep 13, 2013 8:52 pm
wassup wrote:... set you back $244!
WHAT?
for get it, ill just mask up the car and redo them on there...
good thing i didn't go at it..
