Wind blocker in NA6 with style bars
chrislevingston
Postby chrislevingston » Thu Dec 06, 2012 1:36 pm
I purchased a perspex wind blocker off the forum, and it fitted perfectly with my style bars.
However, increasing arthritis means that I no longer have the strength or dexterity to zip open or close the rear window, due to the lack of clearance between the top of them and the roof :cry:
Does anyone know if an NB wind blocker will fit if style bars are fitted?
I really miss the huge reduction in buffeting that the perspex blocker provided (I must dig it out and put it up for sale, I guess).
Chris
Re: Wind blocker in NA6 with style bars
Postby KevGoat » Fri Dec 07, 2012 11:49 am
Hi Chris
I have a NA and recently fitted a BD roll. I didn't want to do without my trusty NB windblocker so looked up a few threads about it.
Most appeared a bit complicated, but I found by turning it around, it bolted straight in!
I have recently taken it out and bent up the brackets slightly so that I could have the flip up section up without it hitting the bar.
Works great!!
Here's a couple of pics taken before I adjusted the brackets:
Hope that helps...
Postby KevGoat » Fri Dec 07, 2012 11:55 am
Hey Chris
Just noticed you are from Adelaide. Not sure whereabouts.
I am down South at Hackham - so if you want to come down sometime & check out what I did you are quite welcome ...
Kev.
chrislevingston
Postby chrislevingston » Fri Dec 07, 2012 12:04 pm
Thanks, Kev - email sent.
Chris
Postby KevGoat » Fri Dec 07, 2012 12:17 pm
chrislevingston wrote:Thanks, Kev - email sent.
Chris
Have replied with my details. Look forward to meeting you sometime :D
