Bloody Central Locking - NA6
LuckyCat
Postby LuckyCat » Fri Nov 09, 2012 9:46 am
This morning I went to unlock my car and it wouldn't engage the unlocking mechanism. To cut the story short I clambered in via passenger side but the drivers door would not engage manually either. So after removing armrest, door handle cover and the door cards, went about trying to sort it out. Everything looked tight, but I eventually worked out the brass fastener that attached to tow of the arms had moved just enough so that the central locking mechanism wouldn't fully disengage.
Also observed a nice little gouge on the inside of the door card where the fastener must have been catching.
Has anyone experienced this sort of problem before?
cheers
chris
Tedsmx5
Vehicle: NA8 - Supercharged
Re: Bloody Central Locking - NA6
Postby Tedsmx5 » Fri Nov 09, 2012 10:02 am
Similar problems with aftrermarket C/L but they don't cause many faults. It seems the brass fastener was badly set up ( if it had been mounted so it did not catch it would still be ok) I'd check all the fittings and all should be good.
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
Postby bruce » Fri Nov 09, 2012 12:24 pm
You do know it's an aftermarket kit as the NA6 never had central locking as standard.
CaptainNate
Postby CaptainNate » Sun Nov 11, 2012 12:27 am
My drivers side C/L doesn't even work :mrgreen:
The passenger side locks and unlocks as required, and the immobilizer works like a charm.
I've been meaning to pull everything apart and have a proper look.
From what I understand from a small peek, I've actually lost a part that connects the C/L motor (or mechanism, whatever) to the locking mechanism. The lock itself is super tight, so I need to get some graphite powder in there to loosen it up.
If you find a solution, definitely give us a report!!!
