Fire extinguisher
mitch_f1
Fire extinguisher
Postby mitch_f1 » Mon Jul 23, 2012 6:37 pm
Where do you get them refilled or checked over? At the last MX5 day I got pulled up because mine didn't have a stamped swing tag thing on it.
Re: Fire extinguisher
Postby Hammer » Mon Jul 23, 2012 6:40 pm
Usually by the manufacturer. Ie. Chubb etc.
But usually it's as cheap to buy a new one than getting it refilled (especially when they're on special at around $20ea)
mitch_f1
Postby mitch_f1 » Mon Jul 23, 2012 6:44 pm
What about getting their inspection tag stamped?
Hjt
Postby Hjt » Mon Jul 23, 2012 7:17 pm
err mines not tagged. :S I have pressure showing though..
MiGoreng
Postby MiGoreng » Mon Jul 23, 2012 7:36 pm
Isn't it cheaper to just buy from shop instead refilling? plus fire extinguisher isn't necessary at track anymore, according to new rule I think anyway.. :?
project.r.racing
Postby project.r.racing » Mon Jul 23, 2012 9:07 pm
correct. cheaper to replace than refill and tag.
mitch_f1
Postby mitch_f1 » Mon Jul 23, 2012 9:44 pm
But if you have just purchased it, it needs a tag on it. Where does one go to get that AS1851 maintenance record tag stamped
mitch_f1
Postby mitch_f1 » Mon Jul 23, 2012 9:48 pm
This tag
A scrutineer at the last mx5 track day was giving me strife for not having this tag stamped
Zcootz
Postby Zcootz » Mon Jul 23, 2012 10:00 pm
I'm not sure it's a CAMS requirement that they need to be stamped (or reinspected at a given interval).
Your local fire station should be able to do it.
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Postby manga_blue » Mon Jul 23, 2012 11:20 pm
If there's no tag on it then scrutineers check the date of manufacture which is stamped on the body near the base. It's cheaper to replace than to inspect. Over time your house gets progessively safer as it fills up with perfectly good fire extinguishers.
Zcootz
Postby Zcootz » Tue Jul 24, 2012 11:48 am
manga_blue wrote:If there's no tag on it then scrutineers check the date of manufacture which is stamped on the body near the base. It's cheaper to replace than to inspect. Over time your house gets progessively safer as it fills up with perfectly good fire extinguishers.
I just checked the CAMS manual, there was a change made this year. It's as Magna states, there's no need for a tag but if it's not there they run off the initial fill date stamped on the extinguisher. That date must be no more than 3 years old for a AS1841 extinguisher.
Murray Walker
mx5racing
Postby mx5racing » Tue Jul 24, 2012 9:46 pm
The rules for CAMS schedule H have changed and they're no longer required for any CAMS speed event or race meeting.
http://www.camsmanual.com.au/pdf/10_gen ... 2012-2.pdf
Stupid rule but that's what it says....
Most scrutineers are not aware of this rule change so you have to help them understand what it means.
mitch_f1
Postby mitch_f1 » Tue Jul 24, 2012 9:52 pm
That's great, thankyou very much :)
Postby manga_blue » Tue Jul 24, 2012 10:22 pm
mx5racing wrote:The rules for CAMS schedule H have changed and they're no longer required for any CAMS speed event or race meeting.
Not by my reading of the schedule, Chrs. It seems to say that extinguishers are no longer required for race meetings but still required for speed events, which is what most of us do when we have club track days.
CAMS Schedule H wrote:Each automobile in any competition other than non-speed events or race meetings must be equipped with a fire extinguisher which complies with the following conditions and is properly fitted at a suitable location.
mx5racing
Postby mx5racing » Tue Jul 24, 2012 10:52 pm
Yes you are correct. I left out a very important "non" which changes the context of the whole ruling.
Any speed event still must have extinguisher(s) as per Table 1 at the bottom of the Schedule H ruling I linked to.
The Club days run under AASA regs not CAMS so it may be different again.
For the cost of an extinguisher I would advise everyone to get one. How this ruling came to pass at CAMS is beyond me... Fingers crossed it does not take an injury for them to come to their senses.
Users browsing this forum: No registered users and 19 guests
