Vibration and a creaking noise in my NC
eastla
Postby eastla » Wed Jul 18, 2012 9:54 pm
I have two annoying issues in my NC that may be connected.
1. When I turn hard left hand corners I hear a creaking noise from behind the drivers seat. Thought it was in suspension or a dry bush at first but I think it is higher in the car, sort of rear window height or higher, not sure how far back though.
2. Occasionally I have a vibration coming from behind the drivers seat, similar height as my point 1. Comes on when driving on rough roads and also when I rev engine to approx 3k.
Anyone else had similar issues or can suggest where to look?
2007 MX5 LE
JBT
Re: Vibration and a creaking noise in my NC
Postby JBT » Wed Jul 18, 2012 10:03 pm
The seat back rubbing on the trim there can make some annoying noises. Try moving the seat forward a smidge and see if it stops. Use some leather stuff or Aerospace 303 or similar on the seat back from time to time.
Postby Regie » Wed Jul 18, 2012 10:24 pm
Yep I got that noise also..seat back rubbing on the trim near the seatbelt
eastla
Postby eastla » Wed Jul 18, 2012 10:27 pm
I know that seat noise, it ain't that :(
2007 MX5 LE
Gmi
Postby Gmi » Thu Jul 19, 2012 1:12 am
Do you have chassis brace?
JBT
Postby JBT » Thu Jul 19, 2012 6:09 am
eastla wrote:I know that seat noise, it ain't that :(
Well you'll have to pull the panel covers off from behind the seat and see which of the many plastic thingies (clips, locating pins, cubby locks, etc.) is squeaking. Search on this forum and miata.net for clues and photos showing how to pull that area apart and what to look for.
eastla
Postby eastla » Thu Jul 19, 2012 7:24 am
Gmi wrote:Do you have chassis brace?
No.
2007 MX5 LE
eastla
Postby eastla » Thu Jul 19, 2012 7:25 am
Ok, thanks.
When I get a chance I'll have to start searching ....
2007 MX5 LE
deanb90
Postby deanb90 » Thu Jul 19, 2012 2:26 pm
Could be the middle cubby hole, the latch becomes loose and needs tightening, there is a service bulletin on how to.
eastla
Postby eastla » Fri Jul 20, 2012 8:05 am
deanb90 wrote:Could be the middle cubby hole, the latch becomes loose and needs tightening, there is a service bulletin on how to.
I don't think so, but where do I find the bulletin?
2007 MX5 LE
JBT
Postby JBT » Fri Jul 20, 2012 10:20 am
Two minutes on Google searching "nc mx5 service bulletins" revealed this: http://parts.arlingtonmazda.com/pages/MX5.html Check the 9th one from the bottom of the list and some of the others.
eastla
Postby eastla » Sat Jul 21, 2012 8:55 am
JBT wrote:Two minutes on Google searching "nc mx5 service bulletins" revealed this: http://parts.arlingtonmazda.com/pages/MX5.html Check the 9th one from the bottom of the list and some of the others.
Thank you
2007 MX5 LE
