Around 6 months ago there was somebody on here who used sandpaper to restore the weaterstrip along the top of their doors, rather than buying new ones for $120 (fair call).
I can't for the life of me find that post/thread again using search.
Please let me know if that was you, I was hoping to find out what exactly you used before I just hit it up myself.
Marty
Restoring weatherstrip by sanding - can't find original post
Re: Restoring weatherstrip by sanding - can't find original
Unfortunately didn't see / don't remember the post from about 6 months ago, but an interesting approach to a common problem.
Ended up doing this, forget the weights but hit it up with sand paper then wet and dry, then Forever Black dye. it looks HEAPS better, all for $20 instead of $120. i've washed it once since.
i'll put some photos up soon.
That's the ticket!! Cheers mate.
So what he said.. i did that.. and it worked a treat!! Recommended restore job. If anybody tries this also, just be careful when removing the plastic clips. Lots of things i read on the net said the weatherstrip slides out towards the rear of the car, bugger that, it was impossible, i used a small flathead screwdriver to pop the clips up but dont push too hard or you'll snap one or two.
My passenger side one has gotten worse than it was originally but it's warped and always has been so I think it was too far gone to start with, but the drivers side one is okay, i'm curious to see if that dye helped much?
I like my girls how I like my cars, topless.
Got the day off so I'll take a photo this arvo. Haven't looked at it in a while, prolly one of those things, when it's bad u notice it more, just haven't noticed it so it's doin its job I guess
- slug_dub
I purchased new ones from Mazda AU before for about that cost, not cheap is right!
I did not have any trouble sliding them out and was able to keep all of the clips intact, so if you do a restore jobby on your existing ones its definitely possible to not kill the pieces getting them off. I might do this rather than buy another set now in light of that info, as I need an improvement on the other cars weatherstrips.
If you were keen on new ones anyway, at the moment a good option would be to buy them from MX5Parts.co.uk as they are considerably cheaper over there!
http://www.mx5parts.co.uk/door-glass-we ... p-414.html
Users browsing this forum: Jeo and 3 guests
