Boot Lid Lifter
gslender
Boot Lid Lifter
Postby gslender » Sat May 19, 2012 8:21 pm
That looks right, just that you need to adjust them to the next notch on each side. Make sure you prop open the boot lid when doing it, with a bit of stick or broom handle etc.
G
-alex
Re: Boot Lid Lifter
Postby -alex » Sat May 19, 2012 9:44 pm
Multi grips are good to move the rods from one notch to the other, also keep an eye on the plastic clip that holds the two rods together it helps hold the tension a bit and keeps them from rattling around while driving.
Sasso - 06/05/10 ♥
