Arhhh hail, may need car covering
Clutch_101
Postby Clutch_101 » Fri Feb 17, 2012 8:39 am
Alas I was caught in the middle of a hail storm driving through Wentworth Falls last week and experienced some mild hail damage! My NA soft has got bonnet and boot dents. I could do nothing but pull over and hear them thump onto the car.
My excess is $600 which ain't flash. Are there any MX5 car covers on the market to protect against this sort thing?
Apu
Re: Arhhh hail, may need car covering
Postby Apu » Fri Feb 17, 2012 8:45 am
If you are driving on the road with no shelter to pull under there's not much you can do is there?
At home, if hail hits...I've told my wife that I'm going to run out with our thickest quilt!
Silvia
Postby Silvia » Fri Feb 17, 2012 9:15 am
Heaps of car covers avail. (e.g.EBay) but you DO have to make a slight effort...
Silver Nomad
2002 NB8C
Postby hks_kansei » Fri Feb 17, 2012 9:25 am
Apu has the right idea.
Most car covers won't actually stop hail damage, they're just too thin.
Best option (other than a garage/carport) is a thick padded quilt/blanket.
Just buy one from the local op shop.
Apu
Postby Apu » Fri Feb 17, 2012 9:44 am
The "better" option is, go to Clarks Rubber/Big W/etc and buy a pack of rubber tiles from the kids department - those great big squares with letters or numbers on them.
Get some old sheets, sew them up into a rough shape of the car - you'll need 2 sets of this - and stuff the rubber tiles into them.
I've been thinking about it, just haven't gotten off my behind to do it. Don't need it to be pretty - just need it to go over the car in a real hurry, and cover it in a hail storm.
Postby hks_kansei » Fri Feb 17, 2012 10:06 am
That's a really good idea Apu.
last time we had heavy hail we had to use whatever we had on hand.
The cars ended up looking like something from Mad Max.
We ended up drapin them in sheets, then laying broken bits of cement sheet over them.
(non asbestos cement sheet, I might add)
Silvia
Postby Silvia » Fri Feb 17, 2012 10:12 am
Yes, though I don't think you need to sew them in sheets....just lay them in place and cover with a cloth of some kind and fix down...
Silver Nomad
2002 NB8C
Apu
Postby Apu » Fri Feb 17, 2012 10:16 am
...all the while getting pelted by golf balls from heaven.
Those tiles separate so easily - if anyone is doing this for car protection, I'd even suggest gluing the joins!
Postby Mr Morlock » Fri Feb 17, 2012 10:19 am
standard car covers will not work. Nothing will work apart from shelter under a roof if you are caught out on the road. You can put thick cardboard on a car and that would work - it will get wet but twin or triple cushion is pretty strong but you still have to fix it in some way and also before the storm.
Postby bruce » Fri Feb 17, 2012 2:42 pm
Just build a carport.
Noddycar
Postby Noddycar » Fri Feb 17, 2012 3:21 pm
I love the weather alerts from Brisbane City Council. Whenever I received an alert, the car goes under cover. The alerts seem to be getting later and later though, I assume due to more people signing up for the free service.
1993 MX-5 Limited Edition - my original Noddy Car
2010 Roadster Coupe Sport - the more civilised (but still fun) daily driver
AJ
Postby AJ » Fri Feb 17, 2012 8:31 pm
removalist blankets work........the good quality ones that are thicker, I can tell you for a fact that they absorb the impact of hail, & generally the larger ones can be doubled over for more protection on an MX-5......... :)
XMX5 Rogues
Entice
Postby Entice » Fri Feb 17, 2012 8:37 pm
hks_kansei wrote:Apu has the right idea.
APU has the WRONG idea.
seriously, if hail is going to dent sheet metal, what's it going to do if it hits your noggin?
Mine's pretty soft and I dont want it damaged,
who here wants to put up their hand and say theirs is thick?
it's a car, insure it, if it's damaged, fix it or replace it (or turn it into a track car).
your head and it's contents (hopefully) is irreplaceable!
More opportunities have been lost from indecision, rather than wrong decision.
PaulF
Postby PaulF » Fri Feb 17, 2012 8:55 pm
Entice wrote:APU has the WRONG idea.
I'm pretty sure the idea was to put the cover over before the sky is filled with large flying balls of ice.
Entice
Postby Entice » Fri Feb 17, 2012 8:59 pm
if you have time to put a cover on, you've got time to seek shelter...
