NB Headlight adjuster...?
Silvia
Postby Silvia » Fri Feb 10, 2012 9:11 am
Looked in my handbook and it says to use the adjuster next to the ciggy lighter ....but I don't have one :?
Did someone take it off our models?
Seems there's a long bolt sticking up from the low beam light itself which I'd guess is an up/down?
Is there a highbeam adjustment somewhere?
Silver Nomad
2002 NB8C
Re: NB Headlight adjuster...?
Postby hks_kansei » Fri Feb 10, 2012 9:15 am
It's probably for European models.
My Mondeo has a headlight height adjuster, it's to cater for towing, or weight being carried in the back.
Since an MX5 does neither of these much at all, it's not missed.
Anyway, the headlight adjuster is the long bolt/screw out of the headlight from memory.
I don't think high and low beam can be adjusted separately.
Silvia
Postby Silvia » Fri Feb 10, 2012 9:37 am
thanks.....high beam is a separate light on this model...
Silver Nomad
2002 NB8C
Postby Mr Morlock » Fri Feb 10, 2012 6:59 pm
the adjusters are integrated in the headlamps - vertical and horizontal. Just lift the bonnet ( not the hood) and you will see them - usually hex head and Philips. That is the standard set up for most headlamps. When you adjust you can see the effect quite readily. The simplest way to get a good adjustment -if 'your' mechanic as one is to use a beam setter - no need to wait for nightfall. The NBP2 has an excellent low beam.
Silvia
Postby Silvia » Sat Feb 11, 2012 9:27 am
I think it's an adjuster for the low beam lights only, but that's ok...the high beams seem well adjusted - and rather good too!
Silvia method; go out on quiet road at night with spanner, stop on flat section, turn on warning lights, adjust setting. Repeat if necessary until perfect..... :D
A passenger may cause need for resetting.....suggest ditch passenger at nightfall.
Silver Nomad
2002 NB8C
greenMachine
Postby greenMachine » Sat Feb 11, 2012 11:26 am
Silvia wrote:... go out on quiet road at night with spanner, stop on flat section, turn on warning lights, adjust setting...
Parking space facing a blank wall. No need to worry about traffic then.
:mrgreen:
Silvia
Postby Silvia » Sat Feb 11, 2012 12:08 pm
Nothing like real on-the-road experience though.
A few blinded oncoming cars and you are then set correctly :shock:
Silver Nomad
2002 NB8C
slimx
Postby slimx » Sat Feb 11, 2012 2:43 pm
Most cars that are smashed require adjustment.
Panel beaters can only do so much sometimes esp. For the money comapnies like aami and just car pay.
In some cases u may need to re-allign ur actual headlight.
Postby Mr Morlock » Sun Feb 12, 2012 3:01 pm
A re alignmment with a beam setter is a 5- 10 min job max.
