Front Mudguard Liner Mounting Screws/Clips, Door Plugs etc..
Posted: Sun Jan 15, 2012 9:03 pm
by Drek
Hi All - My car was missing the drivers front plastic Mudguard Liner when I bought it, and I have found a liner, but my Mazda dealer can't help with the steel mounting screws and clips, or the plastic plugs and screws.. Does anyone know of a later model Mazda etc, that uses similar mounting screws, or anywhere I might get something I can use? I also need new plastic plugs and screws for the doors that the armrests screw into, or maybe I'll just have to trawl the wreckers.. Any help appreciated.. Cheers Derek
Re: Front Mudguard Liner Mounting Screws/Clips, Door Plugs e
Posted: Mon Jan 16, 2012 8:48 am
by Silvia
Supercheap etc. have racks of plastic bags with small quantities of plastic body clips,bolts and other fittings......
Good to take a sample along to compare...
Posted: Mon Jan 16, 2012 10:32 am
by Drek
Thanks Sylvia - I'll give them a try. Cheers
Posted: Mon Jan 16, 2012 5:14 pm
by de Bounce
Silvia wrote:Supercheap etc. have racks of plastic bags with small quantities of plastic body clips,bolts and other fittings......
Closest I have found at SCA (that work) are called SCRIVE CLIPS 8MM - HOLE P/No PP68
Come in a packet of 2.
Posted: Wed Jan 18, 2012 2:20 pm
by Mr Morlock
Bursons also stock or can order plastic fittings. Insofar as screws are concerned you will need a sample or a proper description of the fastener involved.If you have those screws already on the vehicle then you can remove for an id. A specialist bolt and screw supplier can then point you in the right direction.
Posted: Wed Jan 18, 2012 2:42 pm
by tuned_to_fly
Posted: Wed Jan 18, 2012 6:35 pm
by Muzdaman
http://parts.arlingtonmazda.com/Lots of new Mazda parts here. I've used them before, got stuff fast.
Posted: Tue Mar 06, 2012 10:28 pm
by Jim007
You will spend a small fortune buying clips and screws new. If you have a local pick a part go trawling and grab anything you see. I do up a lot of cars and spent 3 hours at Pick A Part one day and came away with about 200 plastic clips of various kinds for bumpers etc at a grand total cost of $5.
Posted: Wed Mar 07, 2012 5:33 am
by de Bounce
After paying the proverbial fortune at supercrap for a couple of clips, I went looking on ebay
Found a seller "thecarson008" who sells them in bulk packs.
Posted: Wed Mar 07, 2012 11:56 am
by 93_Clubman
Jim007 wrote:If you have a local pick a part go trawling and grab anything you see. I do up a lot of cars and spent 3 hours at Pick A Part one day and came away with about 200 plastic clips of various kinds for bumpers etc at a grand total cost of $5.
+1 for your local Mazda wrecker, if you have one local that is.
Posted: Thu Mar 08, 2012 10:43 am
by myredmx5
I am guessing but are these what you are looking for?
Posted: Thu Mar 08, 2012 10:55 am
by marty085
I need those kinda clips for rear mudguards!!!!
the guard clips and screws, i mean. they seem to be what im missing.
