Front Mudguard Liner Mounting Screws/Clips, Door Plugs etc..
Drek
Postby Drek » Sun Jan 15, 2012 9:03 pm
Hi All - My car was missing the drivers front plastic Mudguard Liner when I bought it, and I have found a liner, but my Mazda dealer can't help with the steel mounting screws and clips, or the plastic plugs and screws.. Does anyone know of a later model Mazda etc, that uses similar mounting screws, or anywhere I might get something I can use? I also need new plastic plugs and screws for the doors that the armrests screw into, or maybe I'll just have to trawl the wreckers.. Any help appreciated.. Cheers Derek
Silvia
Re: Front Mudguard Liner Mounting Screws/Clips, Door Plugs e
Postby Silvia » Mon Jan 16, 2012 8:48 am
Supercheap etc. have racks of plastic bags with small quantities of plastic body clips,bolts and other fittings......
Good to take a sample along to compare...
Silver Nomad
2002 NB8C
Drek
Postby Drek » Mon Jan 16, 2012 10:32 am
Thanks Sylvia - I'll give them a try. Cheers
de Bounce
Postby de Bounce » Mon Jan 16, 2012 5:14 pm
Silvia wrote:Supercheap etc. have racks of plastic bags with small quantities of plastic body clips,bolts and other fittings......
Closest I have found at SCA (that work) are called SCRIVE CLIPS 8MM - HOLE P/No PP68
Come in a packet of 2.
Motorkhana Video
Postby Mr Morlock » Wed Jan 18, 2012 2:20 pm
Bursons also stock or can order plastic fittings. Insofar as screws are concerned you will need a sample or a proper description of the fastener involved.If you have those screws already on the vehicle then you can remove for an id. A specialist bolt and screw supplier can then point you in the right direction.
tuned_to_fly
Postby tuned_to_fly » Wed Jan 18, 2012 2:42 pm
http://www.mx5parts.co.uk/fastner-wheel ... p-883.html
All those parts will be on that site somewhere!
Muzdaman
Postby Muzdaman » Wed Jan 18, 2012 6:35 pm
http://parts.arlingtonmazda.com/
Lots of new Mazda parts here. I've used them before, got stuff fast.
Jim007
Postby Jim007 » Tue Mar 06, 2012 10:28 pm
You will spend a small fortune buying clips and screws new. If you have a local pick a part go trawling and grab anything you see. I do up a lot of cars and spent 3 hours at Pick A Part one day and came away with about 200 plastic clips of various kinds for bumpers etc at a grand total cost of $5.
When I was young I spent 90% of my money on Fast Cars, Women and Alcohol. I guess I wasted the rest.
de Bounce
Postby de Bounce » Wed Mar 07, 2012 5:33 am
After paying the proverbial fortune at supercrap for a couple of clips, I went looking on ebay
Found a seller "thecarson008" who sells them in bulk packs.
Motorkhana Video
Postby 93_Clubman » Wed Mar 07, 2012 11:56 am
Jim007 wrote:If you have a local pick a part go trawling and grab anything you see. I do up a lot of cars and spent 3 hours at Pick A Part one day and came away with about 200 plastic clips of various kinds for bumpers etc at a grand total cost of $5.
+1 for your local Mazda wrecker, if you have one local that is.
myredmx5
Postby myredmx5 » Thu Mar 08, 2012 10:43 am
I am guessing but are these what you are looking for?
marty085
Postby marty085 » Thu Mar 08, 2012 10:55 am
I need those kinda clips for rear mudguards!!!! :shock:
the guard clips and screws, i mean. they seem to be what im missing.
