I've fixed it by getting a strip of door sealer (foam strip with sticky back) . Run it across the top of the seal and stick down. Or leave the sticky back covered and draw it through the hollow body seal with a wire to "fatten " it.
So much better
Silvia wrote:This problem has been traced to the black rubber seal across back of engine bay and bonnet getting tired and letting hot engine air past and into the ventilation system under windscreen.
Silvia wrote:Many find the heater vent flap near the glovebox does not quite close, letting heat through. Worth checking, but often gearshift boots are damaged and let heat in from the gearbox, so check that too......but some heat will always come in from the transmission tunnel. Could be good in winter
